Gens ace Tester list---July 5th. 2011
piero
#46 Re: Gens ace Tester list---July 5th. 2011
Beitrag von piero »
Bran hat geschrieben:Sorry piere, didn't fly for over a week now.
But I had a quick test flight with my radian pro, the battery is the same size as the original 1300mah, so it fits perfectly.
Just according the data of the batteries it should do better, as the original one has a 12 or 15C rating only.
It flew well, i hopefully will do a nice long flight sometime this week, weather is going to be finally summer.
I will try to get a log of the flight then!
Hi Bran,
Thank you for this info, and we look forward to your further report when it finish..
Thanks
Piero
torro
#47 Re: Gens ace Tester list---July 5th. 2011
Beitrag von torro »
the batt comes down very hot, but i think it´s ok, voltage drops to 20.5V in tictocs. current is between 90 and 100A. :mrgreen:
headspeed sounds pretty constant.
unfortunately, my rpm-log-thing doesn´t work, a new one is one the way, since middle of june. :roll:
Gruß, Flo
Aeroworker
#48 Re: Gens ace Tester list---July 5th. 2011
Beitrag von Aeroworker »
So, i've tested the Battery some Flights with an Funjet (needs normally ca 40A), my Twinstar (BL), and my E-Flite SU-26m with an 30A ESC.
the battery behaves as good as my other Batterys. Temperatur is low, need the same chargetime and capazity is well.
I have no Modell to test the critical area about 45A, but i think the ratinglabel is ok, the battery is not warm or soft after each Flight.
in my opinion: if the price is right, this battery has a good chance on the German market.
piero
#49 Re: Gens ace Tester list---July 5th. 2011
Beitrag von piero »
Soon will be avaiable in Germany, guys...
So the judgement or testing feedback from you is essential, and we could improve ourselves to make them better & better. 8)
Piero
-Didi-
#50 Re: Gens ace Tester list---July 5th. 2011
Beitrag von -Didi- »
I finally received the pack and will be testing soon!
-Didi-
#51 Re: Gens ace Tester list---July 5th. 2011
Endlich spielt das Wetter hier in Norddeutschland auch mal mit und ich konnte mein Testpack (Gens ace 3s2200) testen!!
Geflogen bin ich den Lipo in meinem Blizzard, welcher mit HK-Motor und 80er HK-Regler befeuert wird.
Vom Setup her sind die Akkus in meinem Blizzard immer im Grenzbereich.
Mehrere Turnigys habe ich mier schon etwas aufgebläht bekommen. Dabei wird der 80er Regler relativ warm! :oops:
Zwei Flüge konnte ich mit dem Gens Ace erst machen, bin aber soweit super zufrieden!! :bounce:
Der Blizzard geht damit richtig gut und der Lipo wird dabei nur lauwarm (Turnigy waren wesentlich wärmer)!! *freu*
Also bis jetzt ist der Akku sehr überzeugend!
Ein Strom-Log werde ich demnächst noch uppen.
Wenn der Lipo sich weiterhin so gut macht, werde ich den demnächst mal im Turn Left antesten!
Heling
#52 Re: Gens ace Tester list---July 5th. 2011
Beitrag von Heling »
Didi, das hört sich ja bisher sehr positiv an! Und vielen Dank für das Mitteilen deiner Ergebnisse. :)
Wo bleiben eigentlich die restlichen Tester? :roll:
Tilo
... schlimmer geht's immer
#53 Re: Gens ace Tester list---July 5th. 2011
Hab meine Ergebnisse in nem anderen Thread eingestellt da ich den hier nichtmehr fand....
http://rchelifan.org/viewtopic.php?f=31 ... t=+gensace
Da haben sich dann ach noch ein paar angehangen. Sorry 4 that
Heling
#54 Re: Gens ace Tester list---July 5th. 2011
Kein Problem, Crizz. Hatte ich auch schon gelesen, Danke für deine Messergebnisse, wie immer klasse Arbeit!
Tilo
#55 Re: Gens ace Tester list---July 5th. 2011
Denke, der Vollständigkeit halber macht es schon Sinn, das ich den anderen beitrag verlinkt hab. Piero weiß davon, dem hatte ich das shcon mitgeteilt, damit er sich nicht wundert wo die Ergebnisse abgeblieben sind. Aber den rest wird es auch interessieren, udn so findet man es auch eher ;)
-Didi-
#56 Re: Gens ace Tester list---July 5th. 2011
Da mir das Testpack sehr gut gefallen hat, habe ich jetzt 2x 6s3800 (werden da als 12s geflogen) für den Logo/TDR bestellt!
Bin gespannt, wie die sich da machen!!
thelars
#57 Re: Gens ace Tester list---July 5th. 2011
Beitrag von thelars »
So Akkus gerade von der Post geholt, 4x Gens ace 2600mAh 11.1V 25C 3S1P und mit Unmut festgestellt, dass die Akkus im Shop gerade 15% billiger geworden sind :( wäre natürlich fies jetzt einfach vom Fernabgesetz Gebrauch zu machen und 4 neue zu bestellen..
Da es hier gerade schüttet wie Sau ist erstmal eh nichts mit fliegen, Akkus sehen soweit sehr gut aus - wenns nochmal schön wird gehts aufs Feld..
Viele Grüße,
Lars
Gauinator 425 TS 3xPichler DS4020, Hyperion HP-DS20-GMD, Microbeast, RJX-Kopf und Hobbymate 3650 1700kV mit 65A Torcster Pro V2
HK-450 PRO TT :] TS 3xTurnigy MG90S, Corona 919MG, bald mit Microbeast, RXJ Kopf und Turnigy 3550KV mit 40A Torcster Pro Regler
TriWiiCopter, 3x Turnigy 2205 1500kv an Hobbyking 18A und HXT900
Walkera 4#6S fürs Wohnzimmer
-Didi-
#58 Re: Gens ace Tester list---July 5th. 2011
-Didi- hat geschrieben: habe ich jetzt 2x 6s3800 (werden da als 12s geflogen) für den Logo/TDR bestellt!
Die Packs sind inzwischen angekommen.
Schick sehen sie aus. :lol:
Spannung der Zellen von 3,79V-3,81V...also recht gleichmäßig.
Masse und Gewicht passen auch!
Beim ersten schönen Flugwetter werden die Packs als 2x6s im TDR und Logo 600SE getestet.
Bin gespannt!!
#59 Re: Gens ace Tester list---July 5th. 2011
thelars hat geschrieben:So Akkus gerade von der Post geholt, 4x Gens ace 2600mAh 11.1V 25C 3S1P und mit Unmut festgestellt, dass die Akkus im Shop gerade 15% billiger geworden sind wäre natürlich fies jetzt einfach vom Fernabgesetz Gebrauch zu machen und 4 neue zu bestellen..
Schreib doch einfach Piero mal an, der ist doch im Forum. Vielleicht bekommst du zumindest einen Gutschein für den nächsten Einkauf. Schließlich wurde mit einem Einführungspreis und Rbatt geworben, das die danach billiger werden war nirgends deklariert, normalerweise geht man von einer anschließenden Rückkehr zum Normalpreis aus.
-Didi- hat geschrieben:Spannung der Zellen von 2,79V-3,81V...also recht gleichmäßig
ich hoffe du meinst 3,79 , sonst wären 2,79 zu 3,81 doch sehr unregelmäßig.... ;)
-Didi-
#60 Re: Gens ace Tester list---July 5th. 2011
Crizz hat geschrieben:ich hoffe du meinst 3,79 , sonst wären 2,79 zu 3,81 doch sehr unregelmäßig.... ;)
Örgs, klar meine ich 3,79V! :oops:
Zurück zu „LiPo / LiIo“
